Mikey593
My Ram 2500 6.4 was suffering from low oil pressure and the Hemi tick was getting worse. I decided to replace the oil pump. When I pulled off the oil pan I found it had a lot of metal shavings in it. I tore down the engine and found that 2 of the lifters had seized up and it had torn up the camshaft. No pushrods are bent. The crankshaft is not too bad I think I can polish it up. Heads and valves are in good shape. I am having heck finding parts, ie. rebuild kits, for the original 6.4. I have found several 6.4 Hemis available, however they are from 2021 and 2020 Ram 2500's. Is it worth making the swap? Will I have to find a matching ECM for the new motor or can I have the existing ECM flashed or reprogrammed. Thanks for your help!
