2015 TYC Projector Upgrade
AngryRams
Phoenix
Those that have made the change from reflector headlights to the tyc projectors... did you have any issues getting the amber running lights to function as intended? mine do not illuminate unless I activate the L/R turn signal... Unsure of what the cause or reason is.
lpennock
Army
Phoenix, AZ
5.9L & 6.7L Cummins
Sure they aren't switchback style? Park circuit is white, turn is amber.
Sent from my SM-T350 using Tapatalk
AngryRams
AngryRams
Phoenix
Pretty sure. They're the standard tyc projectors.. I was going to just buy alfaobd to see if using turn signal as drl or parking light was suffice...
You don't know which lead off the truck feeds the turn signal do you? There is a long connection and a shorter connection
Reticle918
