2016 1500 does extreme heat affect rear sliding window
edhackem
Pittsburgh PA
Here in W Pa we are having an extreme heat wave. Opened my rear slider to help ventilate the cab. When I came back it wouldn't close. Read somewhere that extreme heat affects the switch and it will close after it cools. Any one else hear this? I'm going to wait until after dark and try to close it.
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
Just went out and tried it and it closed with no issues. So apparently extreme heat has an effect on it's performance. It was parked in the shade and had cooled down.
My homelink module does the same thing (same general area). It only happens after sitting in direct sunlight though and typically it doesn't happen if the vehicle gets driven briefly.
Bigskyroadglide
Moderator
Moderator Supporting Member
Montana, officially RETIRED
Hemi 5.7, supercharged
Never heard anything like it . Venting the cab, ha, turn on your AC, put it on auto, let the computer do the work, 5 minutes later truck is cool. It's not the old days where you need wind to do anything. Running with windows open doesn't benefit the driver or the truck. It just makes noise
The only thing i've ever had that was affected by heat,was the screen on the radio in the wifes 2019 Challenger 1320,and they're famous for being affected by heat. Differant heat sink pads and a couple small fans mounted in the dash blowing across the back of the head unit cured that issue
turkeybird56
Central Texas
I live in a slightly warm place, LOL< where the current NE temps are my daily temps in the late spring, summer and fall (actually AC goes on sometime in March and usually stays on till early December). Actually now, we R having a cool wave, high of only 90F today. Have never had a problem with rear sliding window. NOW, I also keep a sunshade in the front windshield and also keep the rear (2) windows cracked when the temps get up there.
Above just "my" personal experience. Not saying heat does not affect, I just do whatever I can to alleviate.
metalchewy
Las Vegas
2010 TRX4
4.7L
Mine got stuck open last week. I had an issue or two closing as a warning a few times before that. Didn't matter whether cool or hot it just stopped working.
I ended up troubleshooting it to the switch. Pinching the wires going into the switch I was able to get it to close.
I've attributed it to my offroad activities loosening the contacts in the switch. A new switch arrives tomorrow.
turkeybird56
Central Texas
I keep sunshade up with these temps to try keep truck a lil cool and protect radio area etc.,. See entry #6.
mands0807
South Tampa Bay Area
2018 Sport
I do as well, but 9 hours in the Florida sun/heat, I have seen my truck thermo as high as 119, and my cheapo parts store vent thermo at 120ish. I can't leave my windows cracked here with the random storms we get(no rain guards on my windows). When I leave work, I just roll my front windows down half way, and hit the auto button on the a/c which is set to 73F. After a couple of minutes, I hit the seat ventilator and roll the windows up :Big Laugh:
turkeybird56
Central Texas
Auto at 73? oh no way, mine is set on between 63-65F. Just depends where I leave it when driving around taking care of "whateva".
mands0807
2018 Sport
Even set to 73, my vent thermo never goes colder than 60 on the drive home from work. Granted, I sit at several stop lights, and barely get above 40mph. My mechanic just got a 1234yf machine, so I might have him check my charge soon.
turkeybird56
Central Texas
My 19 is a 5th Gen, and it had the TSB recall, because they put bad Evaporators in the 1st built 5th Gens, mine being built in April 2018. They pulled out the entire dash and motors and replaced the evaporator and sensors etc.,. My SA put his best mechanic on it. That's my 2019 behind them in the Dealership. I get 45 F-50 F out of vents, depending upon which one. IF I was to clamp the heater core inline, I can get it down to 42 F.
RamDiver
Marlborough, Ontario Canada
2021 DS
It sounds like the AC on my '21 Warlock is the exception, lucky for me. :cool:
I recall measuring 32°-33°F at the vents with the recirculate enabled when it was 80°+ outside.
I usually set mine to 69° Auto when the ambient temperatures are 80°-90° and after about 20 minutes on the highway, move the setting to 70° or with certain company, 71°, otherwise the truck becomes meat locker cold. :cool:
Bigskyroadglide
Moderator
My 24 1500 Warlock Classic, is the same way. I have my AC set on 69. It cools the front and back. By the time my wife who sits in the back says something. as my grandson rides shotgun, it's meatblocker cold..
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
My 2015 AC works extremely well and if a woman is riding with me the headlights go to High Beam fast LOL -( -(
Curmudgeon
York, Pennsylvania
2014 1500 Laramie 4x4 QC, 3.21 rear, 8-speed
I hope this helps - I'm in York County PA, bought my 2014 in July 2017 and it has never since been in a garage except at a shop for service. Almost 117,000 miles.
Both AC and rear sliding window have been flawless. Our temps can't been very different from yours. Weird.
Bettula
