2017 1500 Limited with 37s
RedcardRam
BC, Canada
2017 Ram 1500 Limited
Hi Guys
New here, so please forgive me if this has been discussed before. I couldn't find it if it was.
I have a 2017 1500 Limited(so air ride)
And I have 35x12.50r22 on it...bought it like that. There are spacers above the struts.
2.5" lift.
Has anyone put 37x13.50r22 on a Limited before and kept the air ride?
I don't like the look of 35s on 22rims.
The rims i do like though
Fuel Cleavers
Thanks
shockwire
Saint Louis
Hi Guys
2.5" lift.
Fuel Cleavers
Thanks
You should be able to keep the air ride without an issue. I’m going to Link in a post from the 5th gen folks on this topic too. Your biggest problem is going to be lift. 4” is considered to be a universally accepted lift for 37s.
I agree that 35s look funny on 22s but your rig looks good! I’m personally a fan of meaty tires. I run 35s on 17s.
R
RedcardRam
BC, Canada
Thanks for your reply.
What's the best way to get a 4" lift on air ride?
Revel links?
Thanks
Ramsteen23
MA
Hi Guys
2.5" lift.
Fuel Cleavers
Thanks
Ramsteen23
MA
Here's a thread I found that talks about 37s vs 35s...just some food for thought.
https://www.ramforum.com/threads/35’s-vs-37’s.201281/
I think 35s look good on 22s but to each his own of course and depends on how much meat you want between your rims and the road. I went with 35" Toyo OC AT3 on my 23 1500...the tread/sidewall provide enough meat for me and give me the look I was after. Based on the info in the thread I shared, it sounds like there are some negatives to running 37s (also with 35s) but I'm sure there are guys on here running 37s with a 4"-6" lift that can provide more insight.
Ramsteen23
MA
Revel links?
Thanks
Yes, Revel Links is the way I would go...I installed their basic lift package which provided a 2.5" lift overall and you can adjust the links to get it as level as you want. They also have an Ultimate Lift Package that can get you up to 8" of lift and is made to accomodate 37s.
R
RedcardRam
BC, Canada
I didn't think they made an 8" ultimate kit for 4th gen.....I may be wrong though.
That would be the way to go.
Thanks for everyone's help and opinions with this
Ramsteen23
MA
You might be right...I was shopping for a 5th Gen so not sure...good luck!
Glowz
