Iflybyu
Thanks in advance for any help provided. I took a 2017 3500 Cummins out today and the truck worked and drove amazing except for when matting the throttle from idle or close to idle.
No engine codes or issues other than when putting the ped al right to the mat. The truck is deleted and has a full exhaust system as well as a bully dog tuner and apparently a 40 horsepower tune. Below is a quote from the seller. Is it true that when deleted and tuned these trucks don't like being floored. as I mentioned the truck pulled hard idled great shifted perfect worked exactly as expected except for when matting the throttle at low speeds. Truck has 90,000km.
Quote from seller
"" I did take the truck for a drive once you left and it drove perfect. There was no issue with the acceleration and no stalling whatsoever. I do know that when a truck is tuned like that if you put the pedal to the floor the automatic shut off will kick in and you’re not supposed to do that with those trucks""
Any input would be greatly appreciated.
Mike
Quote from seller
Mike
