2018 ram
Rep22
Canada
2018 ram 1500
Slow to fuel up,but no codes evaporate canister maybe not sure where to start with no codes
You been topping off all the time?
That entire system is not terribly expensive, you might just wanna replace the valve and can.
R
Rep22
Canada
2018 ram 1500
Yes keeping it topped up I see other people have codes not sure why I have none
Cant top of rams as the EVAP will fail, happens all the time to the point it is a known issue here. I don't know why you don't have a code either, usually you will get EVAP code, it is a pretty straight forward fix 10 minutes and a phillips. Start with line and solenoid first, from what I have seen here this can be an issue. So you got line that brings vapor to engine and can. Good luck with it either way, welcome to ram forum.
Not sure if 2018 is the same, I think it may at least be a different part number, dunno for sure.
I have the same issue with my G dam toilet, it is gonna be the death of me. I cant find the dam clog, and the toilet it gonna break my damn floor. I am allergic to paying plumbers, but I have been at it twice cant find it. This is your issue, just like I have a clogged vent, your vent system is why this happens. Does gas pump click off too?
R
Rep22
Canada
2018 ram 1500
If I understand correctly it would be located on top of the fuel tank?
I dunno for 2018, but if it is like 2016 you have a canister near tank I believe, but solenoid line near engine, watch the video.
joshhhh
