2020 2500 Fuses
SamP
United States
Are all fuses in the 2500 under the hood? Was hoping to tie in a dash cam with a fuse tap but I’m not seeing any fuses in the cab. I’d like to avoid punching through the firewall if possible...
Thanks!
John Jensen
San Diego County
Ecodiesel
My 2020 3500 has all the fuses under the hood. If you have Aux Switches you can access #6 under the dash by using the package of wiring, etc that came with the truck.
Scotts26
@SamP all the fuses are in the panel under hood as far as I have seen. There is a grommet on the drivers side firewall for the parking brake cable that is high up and convenient to run wires from under the hood into the cab if you decide you need to. I’ve used it for a couple accessories on my 2020 with no issues.
