2020 with Stock 18" Wheels, 37x12.50?
discodoc
USA
6.7 HO
I have a 2020 3500 4x4 with a Carli pintop lift. I'm running 37x10.50 tires at the moment without issue, but the tires are wearing down and I'd like to go with 37x12.50s, specifically Kanetti Armor Hogs.
Is there any chance I'll be able to run these on the stock wheels without serious rub/usability issues?
mtnrider
Georgia
Are you running aftermarket wheels? If so what is the width and offset. That will determine how much rub you have with that setup
D
discodoc
USA
6.7 HO
No, they are stock. They work fine with the narrow 10.50 tire, I'm just hoping I can cram a 12.50 on to them, too.
mtnrider
Georgia
12.50 wide on stock wheels is going to rub your control arms most likely.
Here is a good reference article on fitment....
Bike_Pilot
Colorado
It'll probably rub the radius arms and sway bar. Thuren sells high clearance options for both that will enable you to run then without rubbing.
olyelr
Kewadin MI
Yea…35x12.5 rubs the radius arms at full lock, 37’s surely will too.
That being said, it doesn't hurt anything, just limits your turning radius ever so slightly.
Fatboy1989
