2022 Total height 2500 laramie 4x4 crew cab diesel
Hdgone
Pennsylvania
diesel
New member. Retired and planning to get back into 5th wheel fun. The specs indicate truck is just over 80" tall. Is that at the highest point including satellite receiver? Any higher than that and truck will not fit through garage door opening. Thanks in advance for responses.
Dean2
Near Edmonton
I have a 3/4 ton gas. With the off road package it sits about 1.5" taller than standard. It fits in my 8' door, it would not fit in a 7' door but I have a high rise canopy on it. I will try to measure just the cab height later today for you.
dhay13
I have a 2018 2500 gasser with off road package and it fits in my 7' door by about 2". IIRC i have about 1.5" clearance above my GPS sharkfin. i think the overall height is 78" n mine but it has been awhile since i checked it
H
Hdgone
Pennsylvania
diesel
Thanks for the responses. Our garage doors have arched opening decreasing from about 83". The next question is how wide is rooftop, side to side.
Dean2
Near Edmonton
Well, if it arches very much she ain't gonna fit. I have a 9' wide door and I have to fold the trailer mirrors to fit in comfortably, make sure you get power fold mirrors. Even with the mirrors folded there is only about 12" on either side. Your box is 71.6" wide at the front, know that from buying a canopy. The cab does not narrow very much as it goes up so my estimate is you are at least 68" wide at the top of the cab. You may have to consider having the door modified. If you do, I would make it a foot higher and 10' wide.
The 8' boxes on the Ram 2500 and 3500 have been tapered like that since at least 1996 when the first new version came out. My 1996 measures 71.5" near the cab, outside of rail to outside, and 69 at the back near the tailgate. The interior measurements have the same relative taper. My 2021 has almost exactly the same measurements. I know this for sure because I was measuring to see if the canopy from my 1996 would go on the 2021.
