2023 1500 Classic - Unamplified 8.4 Inch multimedia pin outs needed
vaprak
Canada
Does anyone have a pin out map for the Dodge Ram 1500 Classic?
I did some searching online and nobody seems to have a schematic for the last 2.5 years that this vehicle was made. The closest I was able to find was a schematic for a 2022 Longhorn with the 12 inch screen but the wiring colors don't match what was in the description.
I did do a bunch of research and Crutchfield recommended the PAC Audio LPHCH41 audio connector. Unfortunately this part doesn't fit my Ram. When I pulled the dash out and looked at the back of the the radio, I discovered that the installed radio is part number P68494521AF Multimedia Center (https://store.mopar.ca/oem-parts/mopar-multi-media-radio-68494521af).
It has the green and blue plugs instead of the single large black and red plug that was on the earlier Ram models (pre- 2022). Normally I'd be able to order PAC Audio's adapter (LPHCH41) but in this particular case that part isn't going to work.
Any help would be appreciated!
