3"-2" 2wd coil leveling kit installation complete !
Ram82808
ImageUploadedByTapatalk1389581149.121222.jpgImageUploadedByTapatalk1389581159.482780.jpg Front only lifts an actual inch. I don't know if that is normal but it is what it is ! Let me know what you guys think. What do you guys suggest i should do next get some more inches for bigger tires ?
argray90
NW Burbs, IL
Nice you could throw a body lift on to get some more lift if you want.
Ram82808
Ram82808
Im actually looking online for the PA 3" lift but damn those instructions make it seem really difficult
argray90
NW Burbs, IL
The body lift isn't very tough just takes some time, the directions can be confusing at first reading it but once you get started its easy to understand. Way cheaper then a suspension lift and still rides and looks great.
CxLxC
HEMI 5.7
Nice truck. Why not go for a suspension lift? Look and ride much better than a body lift
Actually, a BL wont change the ride at all and is CONSIDERABLY cheaper.
Not saying a suspension lift is worth looking at, but let's compare apples to apples...
mcompany
Canton, OH
2011 Power Wagon
My concern with body lifts is when the truck is used to tow. Anyone know if thats a problem for BL?
CxLxC
HEMI 5.7
Not directly... When you do a BL, the hitch stays in the same spot while the body moves up, so it looks a little awkward. I believe you can get this fixed though.
As far as effects on towing, no, it shouldn't change anything.
operator
Professional Firefighter Captain
Marrero, La
View attachment 20782View attachment 20783 Front only lifts an actual inch. I don't know if that is normal but it is what it is ! Let me know what you guys think. What do you guys suggest i should do next get some more inches for bigger tires ?
where did you get your lift kit and how much was it? If that's not too personal of a question I'm interested in leveling mine not too thrilled with lowering my rear end to sit level with front. any help would be greatly appreciated.
Ram82808
Ram82808
eBay item number 331069723174 , Email the seller prior to purchasing this and tell them you where recommended by ReyAlpizar and you need the front spacers the big ones to achieve a 3" lift . Let me know how it goes !
alphaprojects
