3.6L coolant temp
Dwarange
Ca
3.6L V-6 VVT
2019 Ram Classic 3.6L V-6 VVT. Just replaced water pump, thermostat, radiator, hoses and belt. What should be the normal coolant temp? I have hit as high as 228 after repairs. But normally under 220z
Stavinksi
Midwest
that seems pretty warm.What temp is the thermostat? Shouldn’t be 35-40 degrees above that under normal conditions. Especially if it’s winter where you are. If it helps the 5.7 in mine runs 205 ish normally.
It’s a 194 deg
Did you check the thermostat to make sure it was working properly before you installed it.These days the odds of getting a bad "new" thermostat seem to be higher then the odds of getting a good one.For $h!ts and giggles you might want to pull it,and check it.Pot of water on the stove,and a meat thermometer are all you need to check it.
Stavinksi
Midwest
^ ^ ^ it stinks but cheap next step in diagnostic. You flushed coolant as well when you did all that too? Assuming there wasn’t anything unusual coming out? How many miles on this 4 year old truck and what triggered such extensive cooling system work?
D
Dwarange
Ca
3.6L V-6 VVT
pinholes in the factory radiator. Read other forums that said water pump and thermostat would also go. Hoses and belt because it has 94K
D
Dwarange
Ca
3.6L V-6 VVT
Only gets to this temp at idle but only briefly
Yardbird
Western NC
Mine will get to that temp when pulling a long, steep hill, or during a lengthy idle. I don't like it one bit, but that's how it's designed.
I have seen 228 a few times.
