305 45 22 tires on stock truck
Buddy
Ottawa, Ontario - cool town
Looking for advice. I really like the truck as is, I like the stock stance. I just would like wider rubber, fat tires are always nice. I'm eyeing some reasonably priced Liquid Metal 22 x 10 rims. Would like to throw 305 45 22 tires on them. Those tires are 32.8 OD, thats pretty much stock 33, so the look (gap) will be the same. My question is has anyone run this combo on a stock suspension truck??
Thanks people!!
SIhemi
Pennslvanvia
What's the offset of the rims. I'm running 305/45/22 on srt10 replica rims with a +25 offset. I was rubbing the upper control arm. Had to use a 1/4" spacer now everything is fine. I'm also running a 2" level kit just because I didn't like the factory rake.
B
Buddy
Discount tire's site is down, but on Liquid Metals site there are 2 choices of the rim I like in 22";
Both 9.5" wide, 1st 25mm offset, 5 x 139.7 pattern, 78.1 bore. 2nd 18mm, 5 x 115 pattern, 71.5mm bore.
Your truck looks great! Would your rims have been ok before you leveled it?
SIhemi
Pennslvanvia
Height wise yes. It rubs because of the offset. If you go with the 18 offset you should be good. The 25 off set will give you the same problem I had. I think stock is +19 off set. My rims are 22x10
B
Buddy
Thank you, appreciate the advice. So i can safely go with the 18mm and a 305 45 22 on a stock height truck then, excellent!!
Thanks again.
rwalk
Westford, MA
4.7L V8
Your 2nd option (the one with 18mm offset) has the wrong bolt pattern
InspectGWS
Houston, TX
2014 JEEP GC SRT8
And your completely stock suspension? No leveling or lifting? Running any spacers?
Correct - bone stock "Four Corner Air Suspension" - and no spacers...
No rubbing at all and the air suspension has about 4 inches of travel...SRT10 replicas and Yokohama Prada Spec X 305/45 R22's.
B
Buddy
And those rims are 25mm? Well it looks like I may be making some phone calls tomorrow to ask about availability and pricing..... just to weigh things in my head of coarse.... lol
BlownGP
Houston/Baton Rouge
Mine on 305/45/22 Nitto's
These came off a Porsche Cayenne and with the 1 1/2" adapters puts them at around +16 offset.
No rubbing or anything.
B
Buddy
Those look amazing, the truck looks amazing!
Tires don't even stick too far out past the fender line either, nice.
BlownGP
Houston/Baton Rouge
Thanks man
To be honest they stick out a little farther than I thought but I'm used to it now.
N1ck
Regina Sk
Glad I saw this thread, going to be running 305/45/22 on 2/3 drop. I will purchase some 1/4 spacers just to be on the safe side. Don't want to put them on and have rubbing issues for a week while I wait for spacers to arrive.
SSGTD
