325/65r18
mgarnto
Will these fit with no rubbing issues? Putting them on fuel pump 18x9 or x10.
xrsman
Ontario
3.0 Ecodiesel
What's the offset of the rims? Some guys can run 35's on stock rims and get away with it, others say you can't.
M
mgarnto
I'll look up the offset when I can get to a real comp. forgot to mention this will be on a 4" lift.
xrsman
Ontario
3.0 Ecodiesel
Ok the options for 18x9's are 1 offset and 5"BSM or 20 offset and 5.75" BSM
Quite honestly I do not understand the difference in bsm and offset, so bear with me please.
http://www.fueloffroad.com/specs.cfm?id=2568&name=D515
link to the spec page
That just means backspacing. You should be good with the +1 offset wheel! Some guys are doing it with -20 offset wheels. They'll look good! Maybe someone else could chime in and just confirm, but I'd say you're good to go!
DisturbedGator
i went with that size on my truck, bils @ 2.1 on 18x9 -12 offset wheel. they rubbed a little on the wheel well liner but a lil work with the heat gun took care of that
M
mgarnto
Are you lifted or just bils? And With going to a 1 offset would it make more or less rubbing.
DisturbedGator
it rubbed when i turned like 7/8 all the way to the right, i will have to look how close I am to the upper control arm to see if a+1 would be doable with a 13" wide tire. Im on bils only. going with a 1.5 bl as soon as I have time.
M
mgarnto
Any other guys have any experience? Looking to go ahead with the lift within a coupe days, and I do not want to end up with any tire rub.
