33" or 35"
emndive
2011 ram 2500
cummins
Stock BFG;s are getting low. Looking to upgrade to a 33 or 35. It's a 2011 2500 4x4. No lift and I will be using stock rims. Any suggestions? Don't want fender well to look stuffed and would prefer to not have "too" much rubbing. thank you
-Eric
N1ck
Regina Sk
If you are staying at stock height 33's for sure. Depending on tire width you may need to run a small wheel spacer (1/4").
Caldwell
Philadelphia
33'' tires would look good.
assuming you have 17's ?... 285/70/17's are the first size that comes to my mind keeping it stock suspension / rims. There may be some more aggressive fitments out there.
E
emndive
2011 ram 2500
cummins
if need be I have no issue doing a 2 or 2.5 lift up front. And yes 17" wheels
N1ck
Regina Sk
Then I'd personally do 35x12.50x17
Mr. Crowley
Corpus Christi TX
2011 2500 4x4 Crew Cab
5.7Hemi
-Eric
I'm in the same boat as you. I've been doing a lot of reading up on it.
I'm most likely going to be splitting the difference. The 285/75/17 (34"x11.5") should fit the stock height 4x4 HD trucks with no rubbing at all.
It will probably be a few weeks before I get them still, but I'll post pics when I do if the thread isn't too buried.
crcraft
