33 x12.5 20 tires
bri6679
I heard spacers are needed and a leveling kit to fit these tires with stock rims I have 20 x 9 stock anyone try this out and which tires are the best in your opinion for all around use not to loud on the highway? Thank you
Sent from my SM-N915T using Tapatalk
MADDOG
Living in a Firepit
I've got BFG KO2's on my truck and like them a lot. Good traction, beastly looking MT tread pattern but surprisingly quiet on the road.
bri6679
bri6679
Okay cool what size are they
MADDOG
Living in a Firepit
35x12.50R18
Csanders1992
35x12.50x20 cooper st maxx on my 2015 big horn 4x4. I'm running the factory bighorn wheels. These particular 35s measure small so everything fits just fine. Your best bet is seeing if a tire shop will let you test fit
Nick M.
HemI 5.7
I just put 33 12.5 r 20 Toyo R/T's on New fuel rims. I had to change the offset from stock which is 19mm to 1mm on the new rim. The tire is about one quarter of an inch further away from the upper control arm then it was with stock rim and tire so it would only take a half an inch about of spacer to clear a 12 1/2 inch tire on the stock rim 1/4 inch might even do it but it would be close:superhack:
Nick M.
HemI 5.7
You should be aware that many reputable tire shops will not work on A vehicle with spacers. Personally I would never put them on a vehicle but that's just me
Ronan
There is nothing wrong with spacers^^^^ as long as you don't get cheap eBay crap they are fine. BORA is a reputable brand. And if you ask a good off road shop they will tell you the same. I run 1 3/4 BORA's 0 issues.
There are also Fred Goeske spacers and steel ( other good brands) Fred's are a little pricier.
2002dodgenvhelp
