35" tires that are not 80 psi
Gbritton
so cal
I am looking at adding new rims and 35" AT tires. The problem that I keep running into is that there are tons of AT tires but because of the TPMS I need to run 80 PSI tires, and that selection is limited. I only tow a 4000lb boat and would like to run a normal 50-65psi tire but the damn tire pressure light would be on all the time. Also, the ride would be a bit better with the lower-pressure tires. Is there a way to override the dash pressure sensor?
I have a 2015 2500 4x4 with the Rough Country leveling kit.
Any suggestions, besides tape over the light.
Thanks
mtnrider
Georgia
AlfaOBD can change the TPMS thresholds so you can run a lower pressure tire. Just stick with the proper load rated tire though.
J Gerard
I run 45# front and 40# rear in my Ridge Grapplers 35 X 12.5 x 20... Lowered the TPMS setting with the AEV ProCal Snap...easy
DONALD L DIETZ
York Pa
What do you lower pressure too? on rear I dropped 80 down to 45 and light and on front 65 down to 45 and light came on and says inflate to 45 psi im at 60 on rear
No members online now.
ameer73
