3500 clearance marker lights
Texasez
Dallas tx
I've done that on several of my fords. Usually there's not a plug for it. Just T tap into the lights for the license plate or the tail lights. The LEDs don't draw much power. Jut double check the tailgate doesn't hit before you tighten the nuts on it.
MikeP
MikeP
Brooksville FL
There are actually mounting holes already on the truck. I went out and was looking around, i don't see a plug but there is a white wire that is sticking out of one of the harnesses back there its kind of taped back but plainly visible. Not sure if its hot or not. The light should be here in a few days. And FYI it does not come LED from dodge just three 194 bulbs, but i do have leds here for it already.
Sent from my SIII using Tapatalk 2
Texasez
Dallas tx
When you mount it be sure and use locking nuts. I tend to forget until I'm under there trying to tighten them. Then I think to myself crap I hope they don't loosen because it will be a sob to do this again.
MikeP
MikeP
Brooksville FL
Ok light came in. Got it installed, no existing plug it had to be tapped into the license plat lights. It also came with screws but the mounting holes are square easy fix i put the little square plugs made for license plate mounting. Over all it was worth it but it was very hard to get my huge meathooks in there.
MikeP
MikeP
Brooksville FL
That's odd the picture came out upside down lol ill take a few tonight after the sun goes down.
Sagebrush2500
2013 2500 Big Horn
Thanks for the information about this - I may have to do this mod as I like a little additional visibility from behind at night.
MikeP
MikeP
Brooksville FL
I'm at work right now, i will take some tonight when i go to lunch. Sage don't you know upside down is the best way to show off new light mods? Man i thought you were cool.
MikeP
MikeP
Brooksville FL
Here you go.
Edgethis
Bluefield, WV
Looks awesome, do you happen to have the part number you ordered? Other then the bulbs did you have to get anything else?
Whitehemi
FL
Looks awesome ! Got any more detailed info?
MikeP
MikeP
Brooksville FL
The part number is 55277299AA. I buy most of my OEM stuff thru steve white motors in NC. Thay always have great deals on ebay. All you need for the install is the part, about a foot of black and red wire to extend the harness a bit, two of the plastic inserts that the screws go into to secure a lic plate and a few misc electrical connectors. Just need to tap into the lic plate lights. Ill try to do a write up soon but work has me pretty busy.
MikeP
MikeP
Brooksville FL
I didn't see a part listed. It should be around $60
JustinRam1500
