35x12.5 on 20x9 -12 offset?
iwon
So I have a set of 20x9's with -12 offset for my ram 1500 with a leveling kit. And I'm wondering if anyone has run this setup with 35x12.5 mts and if so did you have to do any fender trimming?
PDXRam
Portland, Oregon
You’ll be fine but trim a little bit most likely. I trimmed the plastic of the wheel well cover to fit my 18x9 -18 on 35’s
iwon
iwon
I had one test fit at les Schwab and those guys said that I'd have to do a lot of cutting to make them work?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
There are alot of guys running that set up with no problems, I am going to run 18x9s with -12mm offset and 35s and have read a ton of post that shows this is a fine set up.
A -6mm would probably be better with the 9" wheel but I have not seen any with that I liked.
I have seen 0mm to -12mm ran with 35s and a 2" leveling.
PDXRam
Portland, Oregon
Well I’m a first hand experience. 18x9, -18 offset Fuel Boost wheel on a 35x12.50x18 Toyo RT tire. Just had to trim a little bit of plastic in the front. A lot of the tire shops will exaggerate it from my experience. You see some guys have 20x12 wheels and they get away with trimming just the plastic too
iwon
iwon
Yeah I'd have to trim the plastic in the back the front clears no problem as far as I've seen.
quietpeen
2021 TRX
Hellcat
what level do you have?
PDXRam
Portland, Oregon
I didn’t have to touch the stuff in the back. If the front clears the back should clear without a problem since those tires don’t turn
iwon
iwon
No sorry I meant the back of the wheel well not the back wheels.
