Big_Tim
- Oct 9, 2019
- 1
- 0
- Location
- Birmingham, AL
- 2001
- 5.2 V8 Magnum
Hey fellas, I’ve got a 2001 ram 1500, 5.2L magnum, 154k miles on the body, 500 miles on the rebuilt engine, and 6,000 miles max on the rebuilt 46re 4 speed automatic transmission. Recently I’ve been having issues(surprise) with mild slippage between 1st and 2nd gears. I thought; ok, I’ll add Lucas, and drive easy, and that issue has lessened slightly. But then my speedometer, ABS light, and E-brake/ parking brake light began acting erratically. Replaced the rear speed sensor with no results, and then I replaced the transmission output sensor. When I replaced the output sensor, I noticed it’s magnetic tip had attracted fine metal shavings from inside the tranny. Replaced it, reset the PCM, problem solved for a few days. Removed the new sensor, more metal filings. Cleaned, reinstalled, reset PCM, engine light gone. Speedometer worked normally for about 70 miles then resumed misbehaving. Reinstalled the freshly cleaned original OEM sensor, same results. My question: is there a newer transmission that fits the same specs as the 46re, and if so, is it more cost effective to replace the 46re or get it fixed again? At wits end, please help.
