4th Gen headlight lighting goodies
Status
Not open for further replies.
mdifilippo
NJ
Edited Nov 13: $300 takes it all
I need to make room and get rid of all these colorwerkz lighting accessories that I never ended up using in a headlight build.
I'd prefer to sell this all as 1 lot for $400 shipped within the US (HUGE DISCOUNT) but will list all the individuals with prices below. If individual shipping will be applied as necessary, the more you buy the less I care about shipping charges.
None of these parts were installed but some have been modified. Double sided tape may be missing, the halos are missing connectors, and 1 of the harnesses for the lighting controller is missing 2 connectors (just message me with questions).
All of this was purchased from Lighting Trendz.
2013-2018 Dodge Ram DRL Boards Flow Series (full color control) $150 (new for $210). Nothing missing, both boards have connectors and are ready to go. No controller included, you'd need the flow series style controller NOT the RGBWA controller.
Non-Waterproof 100mm Flow Series Halos. $70 ($90 new). These do not have connectors, they do have the crimps so you could add on 3 pin connectors OR just snip and wire on your own connectors.
Non-Waterproof 80mm Flow Series Halos $70 ($90 new). These have cut ends. You'll need to wire in connectors.
Multichannel Flow Series Bluetooth Remote B606 5V version. $90 ($159.99 new) Not pictured are all of the 3 harnesses which connect and have 4 connectors on each harness. This allows you to connect 12 outputs with 6 individual channels. 2 of the connections have cut ends, all the others have 3 pin connectors. This will control all of the lights above.
to be continued..
mdifilippo
mdifilippo
NJ
Continued
RGBW Demon Eyes (1SMD) $30 (new $55) does not include mounting brackets
High Powered (4W) RGBW Demon Eyes (2SMD) $55 (new $79.99) includes mounting brackets
Waterproof RGBW Bluetooth Remote (with splitter, allows 6 lights to be plugged in) $40 (new $67.99)
mdifilippo
mdifilippo
NJ
If you purchase the full lot I will also throw in a full box of MORIMOTO RETRORUBBER BUTYL GLUE used to reseal your headlight after opening, as well as Diode Dynamics Dodge Ram LED hyperblink Fix Modules (both not pictured).
Send me your best offer if you are looking to purchase the full lot, really don't want to go lower on individual pieces. Message me or if on instagram get me there @thebigbadwolf1500
Either paypal or Venmo (venmo prefered to avoid fees)
mdifilippo
mdifilippo
NJ
BUMP make an offer
mdifilippo
mdifilippo
NJ
BUMP $300 takes it all
mdifilippo
mdifilippo
NJ
Bump. $300 shipped...
mdifilippo
mdifilippo
NJ
Bump make me an offer.
Status
shanmccarthy
