4wd switch
Gr8Blac
Wisconsin
My 2010 ram has the 4wd electronic knob switch without the auto option. Anyone do a switch out to the switch the 4wd auto option?
stimpy433
IOWA
I'm sure just swapping out the switch assembly won't get you the auto option.
WilliamS
Tampa FL
need a different transfer case if that 4auto was an option for your year. Im sure there is something electronic in the truck that will also need programming.
G
Gr8Blac
Wisconsin
I'm tracking that. What I'm asking is has anyone else done a switch and what else is needed.
quietpeen
2021 TRX
Hellcat
I haven't done the switch, but Like WilliamS said you would need the proper transfer case. Then there would be the issue of making the computer know that the 4 auto transfer case and switch are installed and making them work. That's also assuming the proper transfer case is physically a direct swap.
Tim7139
Alberta, Canada
2020 Classic ST Crew 4x4
5.7 Hemi w/8 speed 3.92 gears
Lurchav8r
