4x4 Suspension
Picton
Houston, Texas
2015 - 1500 Express CC 4x2
Guys. Do 4x4 1500 Rams have any sort of upgraded suspension or shocks similar to Chevy's Z71 option? Or are they all the same no matter if you have 4wd or 2wd?
Picton
Picton
Houston, Texas
Man...that's a shame. At least Chevy offers an upgraded suspension option. Oh well...I love my Ram though. Perhaps Ram suspension is on par with Z71 upgrades anyway. I'll hope so.
LB3711
Trumbull, CT
3.6L V6
It's called powerwagon. Beats any "upgraded" Chevy shock setup
Sent from my tapatalk equipped AT&T iPhone 5
Caldwell
Philadelphia
If you want a shock upgrade like the Rancho's that are offered with the Z71 package on the Silverado's... BILSTEIN SHOCKS
Riccochet
Somewhere around Charlotte
2020 2500 Laramie Longhorn
FX4's also come with an upgraded suspension.
You really can't go wrong with either Bilstein or Rancho.
cajun87
Louisiana
The outdoorsman is the equivalent of the chevy z71 or ford fx4
cajun87
Louisiana
All the "upgraded" suspension is, is rancho shocks. Don't buy a z71 fx4 or outdoorsman because the suspension is "better" because you will never notice the difference. The packages now a days are a trim level thing. I just bought an outdoorsman in may but i bought it because of the trim level package.
audio1der
Airdrie, Alberta
To add to the "it's all the same" conversation, a friend and I have now swapped rear springs from my '12 CC 4x4 Sport and his '13 RC 2WD Express. They're about the most opposite trucks you could get and the springs are the same.
Bombdigitty
Ive never looked into it, but I was under the impression that the Ram TRX 4 was equivelent to a Z71 type suspension..
Always thought of them, and the FX4 to be the "factory offroad package"
myoung84
Tulsa, OK
2012 Power Wagon
Agreed! The PW is the best bet if you want a real offroad truck from the factory.
The Z71, FX4, and TRX/Outdoorsman are all in the same category with beefier shocks, some extra skid plates, slightly taller suspension, and some offroad decals. The differences are negligible.
nick84
NKY
If memory serves me correctly, the Z71 package was also the only package available with a 3.73 rear end, as opposed to the 3.42 that was standard on other GM models. I always thought that that, shocks, differential, and skidplates were the only difference. So with the new Ram 4x4, if you have Anti-spin or LSD, and 6 spd with 3.92, or 8spd with 3.21 or 3.55 I think you've got pretty much the biggest parts of an "off road" package. IMHO.
myoung84
Tulsa, OK
2012 Power Wagon
Per the Ramtrucks website, you can get the Outdoorsman 4x4 8 speed with the Hemi, 3.6L, or 3.0L diesel with 3.55s or 3.92s. I don't think any of the 2wd trucks are available with 3.21s. I think the 8 speed with 3.92s is an awesome combo. That gives you a nearly 49:1 crawl ratio in 1st gear, 4-Low! That's better than the Power Wagon at 40:1...
nick84
NKY
^^^ correct. I think a lot of guys forget the real difference between the 6 and 8spd is in first gear not 6th or 8th. IIRC, the final ratio is the same or close in both. So even with 3.21s or 3.55s, the 8spd offers a great low range ratio.
myoung84
Tulsa, OK
2012 Power Wagon
Yep, final drive is damn near identical in both. The 5/6 speed is 0.67 and the 8 speed is 0.667. I know that most have seen the ratios, but here's a couple of screen shots from a spread sheet I put together a while back that shows and compares the ratios. The first also shows the ratios of the 66RFE in the 2012 and up 2500 Hemi, which is also the same ratios as the 68RFE behind the Cummins.
What you must also keep in mind is the tow ratings. The gear ratio is what really determines the tow rating, not the transmission. If you want a 10k lb plus tow rating, you will have to go with the 3.92s.
rizzkid12
2021 Ram1500 4x4 Warlock QuadCab 3.92 5.7l V8
5.7l V8 Hemi
the air bag suspension is an upgrade. no other manufacturer offers this
NavyGuy2007
Oak Harbor WA
6.7L
Loving my 3.6/8spd Outdoorsman, only wish I had the cool bed side decals! Maybe I can find them online. Got a good look at the stock skidplates when I was installing my side steps, there ok, better then nothing, but theres better aftermarket ones out there I'm sure. What is nice is the rubber floor mats were standard, didnt realize that until I picked the truck up which is cool because I was going to buy a set anyways!
Chewy
Bettendorf IA
V8
All I know is with 3.92's and the 8 speed, I can break the tires loose while rolling a couple of MPH. 1st is NUTS on the thing.
TRCM
USN, Retired
Newport News, VA
2012 1500 Laramie CC 4x4
Not true.
I had an 08 Silverado 4x4 that was NOT a Z71, and it had the tow package with 3.73 gears and locking diff and all the other goodies. It was considered an LT1 trim level, which is below LT2 & LTZ....
