5.7 with 6.4 cam and intake makes no bottom end
Hemi81
South Florida
5.7 Hemi with 6.4 cam and manifold
I have a 2012 ram 5.7 with 120k miles
I installed an SRT 6.4 cam kit with MDS delete from AMS Racing. Lifters, timing kit, etc. I also purchased a used 6.4 truck intake manifold with 6.4 injectors. I installed Texas Speed and Performance long tube 2" primary headers and cats. I had a tuner set it up after the instal was complete. Now theres no bottom end. Won't break the tires loose. The tuner says its because the torque curve has moved up the RPM range. I was under the impression this set up would yeild some higher torque values and really wake the truck up but now I don't know what to do. I had more power before the performance parts.
Providing the tune is correct because the tuner succesfully works on some high end / high horsepower cars.
Is there any sensors or anything I should look into to fix the bottom end?
What would cause this? I do have a bad ABS sensor that was bad before the fix.
Sure it'll make more torque,but it's way higher in the rpm band. About all you can do is stick a high stall convertor behind the engine,so it'll flash to a higher rpm to help get the truck moving,other better option would be to swap an 8 speed into it,as the stump pulling 4.71:1 first gear of the 8 speed will help,but even the 8 speed would benefit from a higher stall convertor with that cam.
You do realize the non-mds 6.4 cam is a pretty aggressive cam and is designed for a 10.9:1 compression 392/6.4 with a manual transmission behind it,it's not designed for a 10.5:1 compression 345/5.7 with a poorly geared 6 speed automatic behind it.
You're giving up 47 cubes and almost a 1/2 point of compression ,not sure how you figured that cam would be a good truck cam,as you can't offset those factors with-out a whole of rpm,consequently bottem end torque is going to go bye/bye on you.
H
Hemi81
South Florida
Wild one. I didn’t realize that. Guess I really stepped on my d***. I’ll look into the 8 speed but damn I really thought this cam was a good one for this.
Nope,you got sucked in,lol
mrp2112
canada
5.7 hemi with a 6.4 cam
mrp2112
canada
i got my cam from summit racing i thought i read all info and it said stock cam for a 6.4 will work in a stock set up on a 5.7 i used my stock valve spring the motor runs great but for some reason i get these codes p2127,2167,2166,2116,2115 and cant clear the stock cam #is 05037379BC from summit
HarryS
Air Force
Clovis NM
Those codes have nothing to do with a cam. They are all throttle position/pedal position problems
ezmoney
If I get the 6.4 intake from Moe's and put it on my 5.7 will I lose bottom end power like op did, or is it the cam that is causing his problems?
It's the cam,the 6.4 intake will make more torque down low,in comparision to the 5.7 intake,as it has longer intake runners,but the 5.7 intake will make more hp above 6,000 rpm,as it's short runners are shorter then the 6.4 intakes short runners.In a truck you want torque not horsepower,and that's where the 6.4 intake shines.
Fatboy1989
