5.9 magnum runs like crap
BLKDODGE04
Wataga, Illinois
4.7 Magnum
I have a 98 dakota that has had a 5.9 magnum swapped in it from a 97 ram truck. Was originally a v6, always been a 5 speed. Gauge cluster don't work. If truck idles for a period of time it will start to stall and eventually die, you can hear the intake sucking in air. I changed plenum gaskets and cleaned everything good. Seems to do this more at an idle but maybe just seem to notice it more idk. Sometimes it seems like it is lacking power going down the road but it runs like a striped ass ape when it runs right. Any ideas what could cause this intermittent miss? I changed cap and rotor also and plug wires. Also pickup inside distributor, can't remember what its called.
Shadow_Death
Killeen, Tx
I'm just guessing here but maybe check the IAC to see if it's dirty. Also check the port that it goes into. Mine was gunked up really good and required that I cleaned it.
See album here.
The most this will cost you is time,a can of TB cleaner, a old toothbrush, and some rags. I used B12 Carb and Throttlebody cleaner on mine. The truck woke right up after that.
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
I took IAC out and cleaned it, it was pretty bad, so was port it goes in to. Didn't seem to change much. Sometimes it will idle great and other times it will idle like ****. Seems like a hit or miss problem
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
How critical are o2 sensors with these motors? I know some motors will run just fine with them unhooked and others will do funny things. Mine are currently unhooked.
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
Yeret
Professional Procrastinator
Behind a computer saying, "looks easy enough..."
5.9 Magnum
Plug the O2 sensors back in, especially the upstream one. These are critical for the ECU to properly adjust and maintain fuel/air mixture. Unplug 'em and the ECU can only rely on MAP and TPS readings to try and adjust the mixture, which will result in the engine running excessively rich. O2 sensors are there for a reason.
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
O2 sensor wiring harness has been cut, can someone take a pic of the wiring on their sensor and how it is color coded? I tried looking online but couldn't find much or at least not the right wiring diagram.
SYKRAMMAN
Banned
Jersey shore
06 Mega
Where is it cut at? If it's just the plug end then your good cause when you buy a splice in o2 sensor it comes with a wiring diagram.
BLKDODGE04
BLKDODGE04
Wataga, Illinois
4.7 Magnum
Yeah its cut on o2 sensor side, just pigtail is cut off. I just need to know what color to run to what color. If I remember correctly new o2 has 2 white a grey and a black. Truck side is all different colors. Think there's a black with blue stripe which is ground I think. Then there's an orange with green stripe I believe, I'd have to look for sure. Just need to know which wire goes to what.
svdsinner
5.9L V8
Have you checked the catalytic converter? Blown intake gaskets often destroy them, and without O2 sensors, you would get no warning.
Big_Al
Pcm and harness all from same truck as motor as far as I know
That is likely the issue with the gauges. FWIW....Al
Was with my swap using a 97 5.9 ECM in a 99 Ram.
Arturo Rojas
