5 inch lift.....help!
badandygonzalez
As I have mentioned once before, I am doing a five inch lift to my 98 Dodge Ram 1500 4wd. I have all the parts to do the front, but I had asked advice on lifting the rear. A 3 inch add a leaf was recommended a few times and that seems to be the best way to go for me. The only problem is I cant seem to find a 3 inch add a leaf for the rear. Im hoping that maybe one of you have done this before and can help me out. What would you recommend? Thanks in advance!
Magnum5.9
01 ram 1500 4x4
Magnum 5.9
Google is your friend, search for lift components for your truck. Or just leave it with 5" up front and nothing the the back so it is leaned :)
B
badandygonzalez
The Skyjacker r370 add a leaf was my first choice. But the rep I spoke to at 4wheel Part said it was 3" wide add a leaf and wouldnt fit the Dodge 2.5 wide springs. Maybe he misunderstood it was a three inch lift and not three inches wide? So you believe it will fit John123?
DodgeHimRamHer
Spotswood NJ
5.9 Magnum
That aal is 3" wide. Trust me I ordered it thinking the same thing and it was too wide. They are actually still sitting in my shed cause I have no use for em
noraa73
