5th Gen seats in a 4th Gen?
REDinAZ
Arizona, USA
2017 Crew
5.7 2wd 3.92
...just looking at a few pictures of used seats for sale on eBay the bracket design/styles on the 2 don't even look close.
Sdpadrez
Was there ever a definitive answer on this?
Lsujker
Baton Rouge
Thought I read somewhere the classics with a particular package had the 5 gen seats. Think my classic express with bucket seats has them. Let me see if I can snap a pic.
Lsujker
Baton Rouge
Sorry I have seat covers. The pattern is show on new rams I believe. Know it’s not definitive but maybe you have a chance.
Mpgrimm2
Supporting Vendor Navy Badge
SC
2022 Ram 1500 (5th Gen)
5.7L
While the 5th gen HD 2500 seats will bolt up, the connectors, wiring and modules are different/not directly compatible with a 4th gen.
If you want a chance at getting seats to work currently in 13-18/classic 4th gen, get 13-18/classic 4th gen seats.
Lsujker
Baton Rouge
So it will fit perfect! Just need the seats with that bar you grab to slide back and forth.
NikNak
MidSouth = TN
I have 2017 1500 2WD Std Cab Tradesman Express(= Ram Classic now). I added Katzkin leather to my two front seats, arm rest box etc...
I bought an 2022 2500 Tradesman with vinyl seats because I'd measured the bolt pattern and they will swap... I did realize later that the wiring harnesses do not match. Neither have heated seats. The connectors and wiring loom for the airbags/weight sensors etc... are different. So ... no swap. I don't want to unsleeve the old leather, I'll just keep them as they are.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
I bought 5th gen seats to put in my 4th gen they did not fit at all the seats came out of a crew cab 1500 mines a 1500 quad cab so I ask also will the 5th gen fit the full size 4th gen?
Your answer is in your question.
Ashton
VA
'18
Are the 5th gen hd seats power portion still operated seperately from the bcm? I started a thread of my own a while back with converting manual to power seats that i never ended up finishing. Now that i have some cash to throw at the project i was able to find a 5th gen hd limited seat. I don't care about the cooled function or leather. I am only using the frame and the motors. All the wiring, airbag, cushions and covering will be used from my old seat.
