6+-or tow/haul
jay c
Las Vegas, Nv
Which is better for disabling MDS while doing city driving and occasional WOT runs?
Team Destrucktive
NYCruiser
Yonkers, NY
Probably tow/haul. That mode holds gears longer and disables 6th gear.
If don't want the shift points altered, then use manual mode. You could use 4+- or 5+- around town too. Then just shift it manually when you want to get on it.
audio1der
Airdrie, Alberta
Using tow/haul also uses the engine to downshift which helps the brakes last longer.
Holding the gears longer is AS important as not shifting into its highest gear at every waking opportunity.
jay c
jay c
Las Vegas, Nv
Thank for your advice, I like turning off mds while I drive around town and I would put it in 6 to do it. I recently heard tow/haul is better for the 6 speed tranny tho, so I wanted to start using that.
Team Destrucktive
Searay245se
BrookPark Ohio
2015 Power Wagon Laramie
I use tow/haul in the city and 6th manual on the freeway.Seems to work good this way for my driving habits.
sausec17
Banned
ATLANTA
I've used both. I now just use 6 around town. The constant "non-smooth" shifting made me feel uncomfortable in tow-haul, and as we know these trannys have enough trouble of their own, didnt want to add to it.
Glowz
