8.4 Touchscreen Delaminating?
14MDRam
Rising Sun, MD
At first I thought someone had hit my screen and cracked it. Upon further inspection it appears its coming apart. It has gotten supper annoying as its thinking the clock is being touched constantly and it keep asking if I want to change the settings.
I'm assuming replacement is the only solution here, correct? How much of a pain is it to replace? Price wise is it better to go OEM or aftermarket with modules to retain factory options?20211004_083808.jpg20211004_083907.jpg
Gordo2212
Mississippi
2018 3500 Tradesman
6.4 L Hemi
There’s multiple threads on this issue already. Some folks have had it replaced by dealer covered by warranty. Some have replaced the screen itself.
Rav3ncroft
Indiana
2018 RCSB Sport
If it's still under warranty work with @RamCares or Uconnect. Replacement by a dealership will be around $1200 for OEM. I just had mine replaced under warranty but had it quoted prior to Uconnect saying it was covered.
co-pilot
houston,tx
mine did the same exact thing.......like everyone said try dealer first....
ksebat
Suffolk VA
I just had my Connect 8.4 replaced by the dealership still under warranty due to screen delaminating, however my navigation is not working and i cannot connect to Uconnect thru App it worked before the replacement, it says my location is Oakland CA and actually live in Suffolk VA. Dealership said they tried to reset everything and no joy. They want to do a diagnostic check on the radio and possibly may have to order a new radio. When i talked to Uconnect they couldn't see the replacement radio in their system (Siruis XM Guardian) and said they probably didn't enter it in the Star Data Base. Dealership said they did. Any body else have this issue and if so does the radio need to be replaced again or is it maybe a soft reset?
Dean2
Near Edmonton
Take it back to the dealer and make them fix it. They messed it up, why is this your problem now?
seabrook
seabrook
Black 2018 Night
5.7 3.92 anti slip
mine did the same i had it fixed under warranty
shellj22
texas
So to fix is the screen replaced or is whole unit replaced? 2018 lonestar edition
Rav3ncroft
Indiana
2018 RCSB Sport
If you go through a dealership it will be a refurbished unit. If you are looking to fix it yourself you can replace just the screen. Plenty of information available on the forums. Just search "delaminating" since there have been multiple threads.
mlwapw
Air Force
San Antonio TX
Cummins Diesel 6.7
They just ordered a replacement for mine yesterday. It was cracked and switching channels and useless.
