83' W150 Rear Differential
Dan Dukes
Missouri
I need any and all advice I can get on rebuilding a Chryco 9.25 with 3.55 gears from stem to stern. I have an idea but this will be the first attempt at this particular task. Thanks younzins.
u2slow
BC, Canada
Cummins 6BTA
Tools and key parts:
- Carrier adjuster tool
- Slide hammer attachments for pulling axle bearings
- Crush sleeve eliminator
- dial indicator to check backlash
- press/tooling to install pinion and carrier bearings
- torque wrench
- seal installer kit is nice, but you can improvise
Goodie1990
