8spd Center Console Removal?
Doc221
Central NJ
Anyone remove the upper part of the center console in the 8spd? The portion where the floor shifter would go and the cup holders are. Im assuming its just clips, but rather check first.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
jeepguy_1980
5.7L
I've removed it a few times. The easiest way is to pull out the cup holders, rubber center tray, and rubber tray at the front. Under each piece of rubber is a screw. Pull out all of the screws and the whole thing will just lift out. The cigarette lighter will still be attached.
The other method (not my first choice) is as in this video:
https://www.youtube.com/watch?v=CDhwjHROOyU
Doc221
Doc221
Central NJ
Thanks.
