97 Ram Shakes Then Stalls When Braking Before It Warms Up
Ordy
Pennsylvania
This doesn't happen in the summer above 80 degrees but....... If I don't let the truck warm up it boggs down when I start to drive. Then when I brake it shakes then stalls. Heavy pressure on the brake pedal when this happens. Like the brake pedal doesn't want to move. I really have to stand on it to get it to brake, then shakes and stalls. Once the truck warms up it's fine. Any ideas?
Ordy
Ordy
Pennsylvania
I should also say it Idles fine. If I let off the brake before it stalls it also goes right back to idling fine.
muddy12
Indiana
The “heavy pressure on the brake pedal” kind of points to a vacuum leak in the brake booster.
Might try disconnecting the vacuum line from the booster, plug it, and see if you still get the stalling.
Ordy
Ordy
Pennsylvania
I'll try that. Thanks!
