99 ram steering wheel swap aftermarket
SLICKKS
texas
So I wanted to remove my oem steering wheel and replace with aftermarket. Easy enough..not so now no blinkers or hazards? What am I overlooking..I took the clock spring out because there's no air bag in New wheel..this is not a daily driver..however I would like the above to work. What do I need to do to get this to work? Thanks in advance
Nealuss
5.2L 318
You still need the clockspring. All of the electrical connections at the wheel go through it.
Spike95
Houston
All of the electrical connections on the column go through it, too? I could see the cruise control and horn, but the multi-function (signal) switch seems strange to go through the clock spring. That said, I haven’t dismantled one on a Dodge.
