jsl6v8
- Jan 31, 2013
- 591
- 80
- Location
- Virginia Beach for the moment
- 2013 Ram 1500 HFE RCSB
- 3.6L V6 And proud.
So its been cold and tons of snow, had like 6 inches of snow, the other day I took my truck out, was tired of being stuck being inside, the roads were good but the hotel I'm stuck at was awful. So no problems, drive to the grocery store when I start up the truck again I get the ABS and Brake light, won't turn off. I've since started the car a handful of times, checked the ABS fuse in the driver kick panel and pulled the battery to see if it would clear, no go. I've depressed the park brake the cable works, the brake release works, it drives fine, I just want those lights to go away. I've read somewhere that it could be a speed sensor, not sure which or where but it also said that you normally don't see any readings on your odometer below 20mph, my odometer has full functionality, at least up to 55 and seems to be accurate. Any ideas?
