HelpImlost
I have a 2010 Ram 1500 Sport 4X4 with 5.7 Hemi. A couple months ago the ABS, ESP, BAS, service 4WD, and traction control lights flashed like crazy. I did quite a bit of research and came to the conclusion it was a wheel sensor. Replaced the right rear sensor and everything was fine for a while. A couple weeks ago all the same lights reappeared but instead of flashing, they stay on consistently now. I can’t use cruise control, which I believe is a safety thing, no big deal. I’ve done tens of hours of research, following wires, and checking connectors but to no avail. I’ve checked brake fluid because I read that can cause issues, but that’s fine. No brake fluid leaks, all wiring and connectors I can find are clean and dry. I read that possibly re-flashing the ABS control module may help, but that costs money I don’t have right now. I don’t have the money to take it to a dealer or repair shop and have them scan ABS codes, but I suppose if I can’t find any help here I might have to bite the bullet and do it anyway. I was wondering if anyone has had the same problem or knows a solution? Any help would be appreciated.
