ABS/Traction Control/Park Brake lights are on
Dirty_white_boy
Canada
So all three lights have been on since i put the motor back in after caming it. It sat for about 18 months. I have had it on the road for six months now and I've just did some work on my 2019 1500 Classic 5.7. Brakes all round. I replaced a front wheel hub bearing which comes with speed sensor. I replace the sensor on the other side and while doing the breaks I cleaned up the rear sensors and reluctor wheel.
I have no codes showing for this issue. Abs is not working...not a big deal but my Traction control is not working and with winter coming I'm going to need it. It's bad enough in the rain, after caming my truck the thing is all over the road. The only thing I can think after research is break switch? If it was the ABS module would it not through a code?
I also have no cruze control.
I should also mention the truck was in an accident before i pulled the motor. My 35s stick out and struck something and ripped the front wheel off and broke the suspension....could this have affected the steering alignment sensor?....possibly causing this?
No members online now.
Steve Holtz
