Adding a 2" leveling kit
BigBadBruins
NY
Hi everyone,
I was wondering if any of you could tell me if bringing the front end of my 2017 Ram 1500 Express up 2" will have a negative impact on the ride of the truck?
Thanks in advance.
JamesQ324
South Bend, IN
Hi everyone,
Thanks in advance.
I just put 2.5" spacers on my 11 Ram 1500 and it didn't change the ride quality at all.
Sent from my SM-N975U using Tapatalk
Ohio5pt7
Ohio
I did a 3" spacer no issues. tons of ppl will tell you to do bils. I say do whatever you want and can afford.
Sent from my SAMSUNG-SM-G891A using Tapatalk all grammar errors brought you by fat fingers and auto correct.
MAJ_Charlie
VA and NC
I ended up doing Bilsteins on my leveling. Of course at the time I had over 195k miles on my originals so I figured it was time to change them anyway. Since I plan on keeping my truck a while longer I decided to do a complete suspension upgrade rather than sink $65k into getting a brand new one from the stealership that use Fox shocks and everything else Mopar for their 3" lift/level. The only "durable" component I kept was the front LCAs which are pretty solid. This worked out for my needs instead of spending $$$$ on an Icon setup (an excellent setup, but beyond what I was willing to spend). Didn't feel the need to change the swaybars, but I might as some point in the future.
https://www.ramforum.com/threads/finally-finished-the-leveling-and-suspension-upgrades.145414/
As far as driving manners...the upgrades took all the "slop" out of the suspension.
Rocco2891
Forest Lake MN
I put a 4 corner Bilstein 5100 kit in set to 2.8" with the Tufttuck 50% payload increase in the rear. It sits a little higher in the front than the back. Looking to get a 2" spacer for the rear. Does anyone have any suggestions on brand or material. I've looked at the Supreme. What's better the aluminum or the high density Delrin? Any help would be appreciated.
2015 Ram 1500
Rocco2891
Forest Lake MN
2015 Ram 1500
Rocco2891
Forest Lake MN
2015 Ram 1500
No members online now.
geneseedennis
