4xdad
- Feb 18, 2021
- 1,788
- 1,775
- Location
- Edmonton Alberta
- 2015 powerwagon
- 6.4
Loader the weight is on the back
I should have said I was referring specifically to farm tractors.Loader the weight is on the back
Most tractor weights are made from Cast Iron not steelWe also steel ballast weights on the front - usually permanently installed - for those times when we're carrying a heavy load on the rear 3-point hitch.
Yes, cast iron. Picky, picky...Most tractor weights are made from Cast Iron not steel
Seriously, new place is 25 minutes from existing place! I live in the hills in Naples, NY! I’m at 1600’ at old house, 1900’ at the new place with a 1600’ hill in between! Naples is The Switzerland of New York!Reminds me of my Dad. He walked to school through 3 feet of snow, up hill in both directions.
Well, that's according to HIM.
According to his brother, their mother would sometimes take my Dad to school on her bicycle (1930s Germany).
Just looks sooooo nice, I am sure U TC of it and maintain and drive it.2000! Had an ‘01 t-top before this convertible! Favorite was a ‘70 1/2!
View attachment 533582View attachment 533583View attachment 533584
Super nice, I'm jelly.Yessir! Joys of life they are!
Full tank of gas with Seafoam! Fresh oil waiting! On a Tender till spring!
Jeeßssss Chill out. All I am saying is Ask what they consider an unsecured load. Negligent homicide because a 40lb bag or block becomes airborne. I seen a large dog hit the back window of a pickup at 110km (70mph), took out window and driver's wife. Imagine what a cement block would do. Above or below siderails ,,Unsecured is Unsecured. Regardless of what it is.Why on God's green Earth would you need to contact DOT about putting anything in the back of your truck? I mean, unless it a hazardous load, or something. If your load sticks up above the side rails you may have to strap it down, but that's a judgement call. Securing any load is a judgement call. Do you call them every time before you load up and head out? No, you don't - and neither does anyone else - even though most anything can fly out of the bed in a front-end collision.
I have a submersible pump that pushes the fuel to the Filler Neck. There are two weld in Bungs (steel) with aircraftwhen you add the auxiliary tank, does it need a fuel pump to transfer fuel? Does it need any special vacuum lines like the original tank?
just asking out of curiosity
Old post but do you have a picture of the filler neck tube with the two bungs. I am installing a ATTA 45 gal tank and my tube is all steel.I have a submersible pump that pushes the fuel to the Filler Neck. There are two weld in Bungs (steel) with aircraft
ss lines and Fittings. One for the fuel and a Vent line between tanks. This will be 72 Gallons added to the 33 Gallon Main Tank
There are DOT regs, EPA regs and the trucks Computer to take into consideration. I did something similar with the Tool Box
in the Bed of my 2008 Big Horn. 36 Gallons added to the 26 gallon main. I could transfer on the fly while driving.
Got a 950 mile range in it.
Malodave
Getting a local rad shop to **** up my feed and vent tube for the positive feed to main 33 gal tank.
Thank
