adding fog lights?
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
I think Dodge makes a kit, with all the parts. Do you have the connectors by the fog holes already?
BAMA BOY
BAMA BOY
Gasden,Alabama
4.7 Liters of fire breathing fury!
no idea ill have to look tomorrow i hope i do lol
05singlecabHEMI
Lilburn,GA
I was wondering the same. I have one side that has the connectors but the passenger side doesnt.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
if you do, I think its as easy as getting a new switch, the fogs and a computer program from the dealer.
BAMA BOY
BAMA BOY
Gasden,Alabama
that would be sweet if its that easy!
shadow11
Banned
Houston TX
Its a simple job. You need the fog lights, foglight bezels, harness that connects the fog lights to the plug under the drivers side headlight and a new headlight switch with fog light control. Only the 06 and up Rams have to be programed at the dealer for the foglights to come on. 02-05 is simply plug and play.
BAMA BOY
BAMA BOY
Gasden,Alabama
thanks fellas ill look in to this when i have more time
mitchman
SC
I put the fogs on my 08. Install is a breeze as stated. There will only be one connector, on the driver's side. The harness to get to the other side comes with the fog lights. The kit is really nice.
Redtruck-VA
Virginia
2003 & 1989 D250 RWD
There are a couple ways to wire the fogs up. I used a kit similar to the one listed here. It is a stand alone kit which has several advantages over the OEM Dodge kit. It doesn't need the main headlight switch to be replaced or PCM flashed, the fogs can be turned on /off with a rocker switch. OEM fogs only come on when low beams are in use. Stand alone fogs can be used anytime regardless what other lights are in use or not. I use mine as daylight running lights. and with my high beams. Keep in mind the PCM controls all the electrical stuff through a 5v multiplex signal, basically the various switches terminate a resistance of different values to tell the PCM what it should do, such as turn on left turn signal, high beam, windshield wiper and so on. Stand alone works outside the OEM system as in Old school stuff. At some point I intend to fool with high/low beam switch to see if I can tell the PCM to turn both on at the same time. Anyway, my 2 cents.. Good luck
Lowrider357
