aFe Winter SALE – 4th Gen 5.7L Ram! Induction + Exhaust
X
XTR Performance
New Jersey
All PM's replied. Thank you for your business everyone. Be sure to check out our other deals and ask us about package deal pricing!
X
XTR Performance
New Jersey
UPDATE: Our current inventory:
First off, a bit of info on the filter type choices to help you decide which is best for your application.
-Pro Dry S:
This is a non-oiled filter. This is the best choice for the Ram owner that wants a noticeable increase in flow, but doesn’t want to have worry about maintenance ( cleaning + re-oiling ) the filter every few months. The Pro Dry S is the perfect balance of Performance, Protection, & Convenience! Pro DRY S provides dramatic airflow increases for improved horsepower and torque performance with 99.2% filtration efficiency
-Pro 5 R:
Pro 5R provides the highest air flow levels for the largest gains in horsepower and torque for times when performance is everything! This is the best choice for Ram owners that want all out Maximum Flow, & do not mind cleaning + re-oiling every so often. Cleaning Intervals will vary based on the driving environment.
Direct Fit Replacement Filter:
Pro 5 R, part # 30-10071
Pro Dry S, part # 31-10071
MagnumFORCE Stage-1:
Pro 5 R, part # 54-10381
Pro Dry S, part # 51-10381
This air intake system produces 12 max horsepower and 23lbs. x ft. torque over the factory intake. Includes a durable 16 gauge, powder-coated heat shield; this air intake system features a washable/reusable conical air filter. Heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles.
MagnumFORCE Stage-2:
Pro 5 R, part # 54-11632
Pro Dry S, part # 51-11632
This Stage 2 air intake system produces 18 max horsepower, 23lbs. x ft. torque and out-flowed the factory intake by 22%. Includes a massive air filter, utilizes the existing lower air box for easy installation, with a snap in heat shield. This intake system also features a powder-coated black tube that replaces the stock intake tract and directs increased airflow with improved volumetric efficiency for maximum performance.
FULL METAL Power Stage-2:
Pro Dry S, part # F2-02001
This FULL METAL Power Stage 2 cold air intake system produces 18hp and 23lbs. x ft. of torque and outflows the factory intake by 22%. Enclosed in the durable 18-gauge, black powder-coated heat shield; this air intake system features an oil-free washable/reusable conical air filter that improves airflow for increased horsepower and torque. This intake system also features a 3-angle adaptor and a heat-insulating mirror polished aluminum tube that replaces the stock intake tract and directs increased air flow with improved volumetric efficiency for maximum performance. One-piece heat shield requires little or no assembly and the filter is constructed with 100% polyurethane for long life and multiple cleaning cycles. This system mounts to the factory lower intake housing.
Silver Bullet Throttle Body Spacer:
Part # 46-32005
Silver Bullet throttle body spacers create turbulence in the air flow at the point just prior entry into the engine increasing horsepower, torque and improving throttle response and fuel efficiency. Silver Bullet throttle body spacers are constructed out of durable T-6061 billet aluminum and using a unique serrated/helix entry to create turbulence at the manifold while eliminating the annoying whistle found in other helix only throttle spacers.
MACH Force XP Cat-Back:
Part # 49-42013
This MACH Force XP Cat-Back exhaust system outflows the factory exhaust by 130%. This cat-back exhaust is constructed of 3" mandrel-bent 409 stainless steel and comes complete with free-flowing muffler, tubing, OE style bayonet hangers, band clamps and all hardware necessary for a hassle-free installation. The smooth curves and increased diameter of this exhaust system helps remove restriction and keeps exhaust gas flowing smoothly for increased horsepower and torque. The system is finished off with a high luster polished 304 stainless steel, rolled slash cut tips for an aggressive style.
WAIT!!!! There’s MORE!!??
Buy any one of the above items & get how much off a Diablosport Trinity ( T1000 ) when you buy both at the same time?? Sorry, too low to post publically. No gimmicks, no freebies, etc. Just the Rock Bottom Price! – please message me for the combo deal pricing!
Contact me with your zip code, & the item #(s) you are interested in for best pricing delivered!!
X
XTR Performance
New Jersey
-Pro Dry S:
-Pro 5 R:
Part # 46-32005
Part # 49-42013
X
XTR Performance
New Jersey
-Pro Dry S:
-Pro 5 R:
Part # 46-32005
Part # 49-42013
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
-Pro Dry S:
-Pro 5 R:
Part # 46-32005
Part # 49-42013
X
XTR Performance
New Jersey
-Pro Dry S:
-Pro 5 R:
Part # 46-32005
Part # 49-42013
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
-Pro Dry S:
-Pro 5 R:
Part # 46-32005
Part # 49-42013
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
X
XTR Performance
New Jersey
TMFMK
