2015 Ram 1500 OE and Aftermarket Parts List Cam/Lifter Repair With MDS.
EdGs
FL
Here's the parts list of OE and aftermarket parts I used on my 2015 SLT 5.7 w/MDS cam/lifter repair.
Cam, lifters, timing components, valvetrain, and associated parts are listed.
The oil pump listed is the Hellcat pump. I used the pressure relief spring from my original oil pump.
The heater hoses listed are for a later model Ram WITHOUT the 3-way valve that routes the coolant to/from the TMU/heat exchanger on the driver side of the 8HP70
I left my 3-way valve electrically connected only.
Please double-check and verify fitment for your vehicle.
2015 RAM 1500 SLT QC 5.7L 2WD 8SPD
201,192 miles
2x 5038785AD MDS lifters, front w/yoke
2x 5038786AD MDS lifters, rear w/yoke
1x 53022263AF MDS camshaft
4x 53022298AA MDS solenoid
1x 6102430AA camshaft bolt
1x 53022243AF camshaft phaser
1x 53022338AB oil control valve
1x 53022317AC crankshaft sprocket
1x 6510763AA crankshaft bolt
1x 53022316AC timing chain
1x 53022115AH timing chain tensioner
1x 4893429AA timing chain guide
1x 68195993AD Hellcat oil pump
16x 68080909AB valve springs
8x 53022087AC Intake valve
8x 53022088AD Exhaust valve
16x 53022090AB valve stem seal
2x 53021552AB Intake rocker assy
2x 53021553AB Exhaust rocker assy
8x 05045515AA intake pushrods
8x 05045516AA exhaust pushrods
20x 6510280AA head bolts, long
10x 6506334AA head bolts, short
1x 53022306AC head gasket, right
1x 53022307AC head gasket, left
1x 53021568AE oil pan gasket
1x 68391488AB water pump gasket
1x 53021521AD timing cover gasket
1x 53021585AD crankshaft seal
1x 53020861AA oil pickup tube o-ring
1x 53021144AA oil dipstick tube o-ring
1x 55056906AH heater hoses (no 3way)
4x Fel-Pro E70599 fuel injector o-rings
1x Fel-Pro MS97083 exhaust mani gaskets
1x Fel-Pro VS50625R1 valve cover gaskets
1x Fel-Pro MS97089 intake mani gaskets
16x NGK 92145 Spark plug
1x Motorad 416192 thermostat 192°
This thermostat failed in less than 1 year, replaced with a Calorstat 192 from RockAuto, no issues since.
I bought enough cheap oil and filters to do a few quick oil changes to help remove any residual schmoo that may have been present after the repair
3x SuperTech 5w-30 oil 5 qts.
2x Fram TG2 oil filter
2x RedLine 5w-30 oil 4 qts.
1x Fram FE2 oil filter
2x 68163848AB OAT coolant concentrate
2x distilled water 1 gallon
Best wishes for a smooth repair to anyone having to go through this situation. Take your time, don't get rushed.
