Jeepwalker
- Sep 8, 2017
- 4,282
- 5,471
- Location
- WI
- 2012 Reg Cab, 4x4
- 5.7 Hemi
I'm just throwing this out there..... Could it be ...Could-it-be....I wonder, the shields being the 'root issue' causing the exhaust manifold to warp? Here's what's making me wonder, I'm just thinking out loud here:
1) The manifolds tend to warp "upwards" on the ends ...and break the bolts there.
2) Just so happens the shields are 'open' on the ends of the manifolds and rather tight at the middle. Therefore the ends cool off faster, esp the outer surface, the surface away from the engine. That would cause the cast iron to SHRINK in those areas FIRST...causing a warping "up" of the manifolds at the ends ...the exact areas where the bolt heads pop off.
3) When I was milling my exh manifolds down they got somewhat hot. Meaning they were warm on the underside (mating surface) and cooler on the outer edge. They warped 'up' a bit. I laid a machinists ruler on them and went "Hmmm". After I let them cool to ambient they were flat across the surface I was belt sanding. So...if you go to belt sand your manifolds, just alternate between them, and take breaks so they don't build up too much heat (and flex up on the ends).
4) Look at the coloration in the picture below. You can see where they get HOT in the center, less so on the ends. It turns out the shield (on my tk ...probably others) is concave in the center ...very tight to the manifold in the very area where it is darker gray (see first pic). It obviously was impeding cooling airflow. By design? IDK. So the manifolds retain heat more in that center area I believe. See pics below. Or maybe the cooling air velocity of the airflow is greater by keeping the center section of the shield closer to the manifold in the center?? Not sure what Ram was thinking there.
5) A lot of older trucks ..and I know Chevy's for sure didn't have a shroud around the manifold...or when they did, it was the whole manifold generally, not predomenately the center section. Or the center section was sometimes 'louvered' to allow the manifolds (my theory) to cool more or less as one, not hotter in some areas and cooler in others. Classic cars usually had open exhaust manifolds and warping was rarely an issue.
Anyway, that's what I'm thinking ...wondering. What do you 'experts' think?
What I did on mine prior to assembly was hammer the concave center section of the shroud "out" more so more cool air can flow around the center section of the manifold going forward. I also hammered 'carefully' the open 'ends' of the shield further away from the manifolds (increased the gap from normal (almost no gap), for better airflow ..and so they contain less hot air (see 'gap' in 2nd picture). Now there is a good equidistant 5/16"-3/8" gap around the trailing lip of the heat shield (2nd pic), where before there was hardly any gap for air to escape the center region of the exh manifold. If there was enough material I'd rather have a wider 1/2" gap.
I wonder how new truck manifolds would last if someone right away removed and re-made different shrouds which were larger or not all the way around or perforated in the center ...in other words, didn't contain more heat in the center area of the manifold and allow the ends to cool first??
What say you??
What say you??
