My RAM is basically GG, so battery will charge at 14.5 initially, then roll down to about 14.2 if I do a lot of driving, and even sometimes drop to 14.0 since the battery not need a big charge. But if OP, all U do is GG runs, short runs, U need to either run it a long way once in a while or put a battery minder/tender on it, or all the electronics on these rolling PC's will pull your battery below the threshold needed to start truck. Remember, OP, even off, there are modules in your truck that are still "ON" pulling voltage.Just something to think about:
If you're in the habit of making alot of short trips - Under 5 miles one-way each time you shut it down and then start it again it could be the battery is slowly dying because between each start of the engine it never fully recovers the charge expended from starting it - In short, the battery is dying by degrees if that's the case.
You have to let one run on occasion long enough to fully recover the charge expended from starting it.
Bear in mind each time you start it, that's another portion of charge gone and you normally cut it off when you get there and restart it to head back. Putting it on an slow overnight charge, like once a week if you do that will keep it from drawing the battery down too low over time, leading to things like starters going out (Burning up) and batteries going bad in general because they were in a state of deep discharge which can damage a battery.
Check your voltages and so on, then if it's charging normally (Within it's expected voltage range) that's something to think about if you're always going to the corner store just down the street and not much else aside from that.
Yeah, was trying to figure out why an external V/R? Trying to work around a failing V/R in alternator? Maybe installed a secondary battery to run optional stuff? Who knows.The other question is why did you need to replace the regulator to begin with? That might answer some of the above questions about the battery maybe being low.
Also as asked above, I would get some actual voltage numbers versus just saying it's "3/4 the way up the gauge". Honestly think there is a good chance you are chasing something that really isn't a problem.
That was the thought I had about it, the OP can check how it's charging and go from there.The other question is why did you need to replace the regulator to begin with? That might answer some of the above questions about the battery maybe being low.
