This is what iit says:
ORC--AirBag/Occupant restraint Fault I1(The I is actually a straight Line) When you click on that, this is what I get: ID :U01 *84 . Actually, My OEM stereo has had "intermittant issues" ever since the Dealer did the air bag recall so I eventually replaced the stereo with a Sony double din stereo"
Now I also have a ABS code that says "low on fluid" that is reared it's ugly head a few days ago, too. Added fluid and reset and it was off for a day and then magically reappeared. Grrrr, I'm trying to sell this truck with 135k miles and NEVER had a issue with anything but a small exhaust leak at the exhaust maniforld/EGR valve location that never set a code or luckily didn't burn up the cat.
Life was fine when I had a sipmle OBDII scan tool that didn't do ABS/air bags
I can't knowingly sell something that isn't right.
Thanks for your time to respond, Brian
