Air suspension
tman75
Wisconsin
I currently own a 2020 Laramie with off road group and air suspension. I want to go from stock tire LT275,65,18 to Rebel tire size LT275,70,18. Will there be any issues with rubbing from the increased tire height and do I need to modify anything? Is the lift the same on the rebel as the off road package?
olyelr
Kewadin MI
The tires will fit no prob.
Im not 100% sure, but with the air suspension i believe the only difference between the rebel/off road package and a normal pickup with air suspension is a minor change in the height settings for each level.
T
tman75
Wisconsin
Thank you. I thought the height was the same. I was just concerned with rubbing if I put the air suspension in the lowest setting or if it went into aero mode with the tire change. I thought the spacers they use were the same for the rebel as the off road group.
olyelr
Kewadin MI
I dont believe they put any spacers under the off road package or rebel package….i think they just have more air in the bags for each of the settings.
I edited my post above….i must have been hammed up when i originally made that post, it made no sense!
