AlfaObd and Obdlink MX+ systems access priblem
kmstreaker
Muskoka
Cummins 6.7
Hi all. I have a 2018 Ram 2500 Cummins for which I've purchased both the AlfaObd for android and an Obdlink MX+ along with a security bypass cable. I can connect the AlfaObd to the MX+ via bluetooth but have not had any luck accessing any of my trucks systems, modules or computers. The AlfaObd make 4 attempts and then times out no matter which system I try to access. The security bypass cable works as it was used to program a new key fob at a local battery place (they couldn't program it until I purchased the bypass cable). So, am I missing a step or something....what am I doing wrong? Thanks for any help that can be offered, Rob
Matt Jackson
Canada
I had trouble connecting with alfaobd initially, have you tried extending the parameters on the access time? Also ensure the bypass cable is plugged in to the cambus all the way aswell as the obd port.
What are using to access it with, windows or android?
Taps
