Alice needs help
MisfitAlice
Denver CO
5.9 gas
my 2002 5.9 gas motor just started knocking one day out of the blue. it starts and runs but as soon as i get to about 30 mph it starts knocking. can someone please tell me what this might be? some suggestions before i drop alot of money into rebuilding this motor. Please help me
SYKRAMMAN
Banned
Jersey shore
06 Mega
Sounds like a bearing went bad. You need to have it diagnosed before throwing parts at it.
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
diagnosed by a reputable shop, that eliminates any dealership
One option that seems like a experienced shop, 8 bays, ASE Certified
COLORADO ENGINE, 5870 W 56TH AVE, ARVADA, CO, 80002, USA
(303) 425-0200
superior engines
6900 Lakewood Place
Lakewood, Colorado 80214
303-233-2342
ASE Certified
MisfitAlice
MisfitAlice
Denver CO
5.9 gas
I did and he told me that i needed to have the top end rebuilt so that means the entire motor. Cant just do the top end. Can anyone tell me where i can get a rebuild and a place that can put it in for me for under 4000? I need my truck for work and i cant work without it
Dodge 1500 4X4
Rochester, NY
Top end is Heads, cam ,lifters, timing chain, intake manifold valve covers, you probably wiped out a cam lob thats giving you that tick at 30 mph like you said, did he pull a valve cover off to verify that one of the rocker arms aren't moving to full stroke, He can do what's called a Leak down test that checks the lower end for wear.
If he's good he should be able to do it for less that 4,000.
Lower end is, Engine block, crankshaft, connecting rods, wrist pins, pistons, rings, crank bearings, connection rod bearings, Cam bearings Oil pump, oil pan.
averageguy
Belleville Mi
hemi
I think he means he wants to do it all and not just the top end. No one can do an entire rebuild plus remove and replace it for $4000.00
Dodge 1500 4X4
Rochester, NY
Alice how did you make out, I lived in Northern Colorado for 6 years and I believe you can go to a pick and pull (Junk Yard) you may be able to get a decent complete Engine Assy, Look for something that has rear end damage, you may even get one that you can start and hear run, Its worth a try, How many miles on your engine.
Raadz
