SoCal Bomber
- Apr 7, 2017
- 103
- 34
- Location
- Antelope Valley
- 2016
- 5.7 Hemi
Going to change the rear diff oil with Amsoil severe gear 75w-140. Do I need a LSD additive?
More than likely you do but you need to find your build sheet or window sticker to be 100% sure. I have seen a **** ton of 3.21 trucks with open diffs but all the 3.92 trucks I've seen had LSD. I believe there's also a way to check your VIN to find out what options you have too.Ok, so I'm going to assume I have LSD, 2016 Express, 5.7 with 3.92 gears. Would that be a correct assumption?
Do you have the original window sticker for your truck...??? Not all 3.92 diffs came with LSD unit.I wonder if the sticker under the diff somehow denotes the LSD, here’s mine with 3.92 and I have the LSD
