Ancel AD610 Elite Scanner
Ludville1
5.7 Hemi Sport Crew
Anyone have any experience with the above mentioned scanner for use with our trucks? My truck threw a ESP BAS code, along with the ABS code. I suspect a bad wheel speed sensor, but my current scanner can't read ABS codes, and AutoZone's scanner can't read them either. I can pick up the scanner for around $100. Tried disconnecting the battery for 30 minutes to clear the code, and it did not work.
aimcgma
