Anyone using rubber bedmat with rambox cargo management system
dynabyhd
Connecticut
I recently purchased a used 2015 crew cab with ramboxes that has a sprayed in bedliner and the OEM cargo management system. Is anyone using a rubber bedmat, like the DeeZee with the cargo management system? Wondering if it will interfere with the function of the bed divider/extender. The sprayed in bedliner is a bit slippery so I would like to find something to use on the bed floor to prevent cargo from moving around and also to provide some cushion when crawling in the bed to retrieve cargo while still using the bed divider/extender.
Bigpaul13
I have a mat in mine, no problems using the divider.
D
dynabyhd
Connecticut
Good to hear. Thank you for the feedback, wanted to make sure before buying a mat. Was thinking maybe the divider would not secure properly when using a mat.
D
dynabyhd
Connecticut
ImNickJames
MA
Can't beat the tractor supply price. I think the width for Rambox is 49", but for that Tractor Supply price who cares about 0.5" on each side.
FYI I have the Ram OEM mat, it works for both RamBox and non RamBox - you just have to cut off the four corners with a razor knife. No problems with the RamBox divider.
EFD317
Cleveland
Yea, you’ve got about a half inch maybe on either side, but the mat doesn’t move around any.
The lights are eBay strip lights stuck under the accessory rails and wired into the factory bed lights. Next is to add a second switch to the bed to turn it and the cargo light on like the have on the newer trucks.
FlaSeadude
Washington, D.C. / Florida
Can any rambox owners chime in?
I have the Rambox bed, but have been satisfied with the factory spray-in bed liner. All of my previous RAMS (2003, 2008, and 2014) also had spray-in bed liners and I never noticed a slippage problem with them...
KSH
EcoDiesel
I put a big floor mat in the bed, like you find at the entrance of office buildings. Thin, keeps stuff from sliding around. No issues with the divider.
TXCOMT
I have the bed rug in my ram box and the divider works great
Yep; same here...used to have a TSC stall mat back here (the thick one), but it would shed tiny bits of rubber when washing the bed. It now resides under my Ram. Hey, it was made to be under animals! Bedrug is much easier on the knees and not nearly as heavy.
TXCOMT
D
dynabyhd
Connecticut
Thank you for all the feedback and suggestions. After comparing all of them I decided to order the Dee Zee DZ86996 Heavyweight Bed Mat. The BedRug was appealing but will put extra money not spent on it toward other upgrades.
